-   -   help (https://www.racingjunk.com/forums/showthread.php?t=30558)
hotrod1994 06-15-2011 06:20 PM
help
DO YOU GUYS THINK I WILL HAVE A PROBLEM WITH POWER BRAKES USEING THIS CAM IT SAYS IT WILL BUT I WANTED A SECOND OPINON
ERSON 488/488 CAM 108 LSA DURATION AT .050 232/234 AND ADVANCE DURATION 280/290
HEERS A LINK TO THE CAM
http://cgi.ebay.com/ebaymotors/Erson...item2c5c8d5c9c
zipper06 06-15-2011 07:46 PM
Normally you need 112/114 lobe ctrs. to have decent vacuum for power brakes, your vacuum could be down to around 10 inches or less, where you need 14 to 16 inches of vacuum for the brakes to work properly. I'm in the same situation with my El Camino and i'm changing the cam out with the present cam i have less than 1/2 petal and i have a vacuum canister for reserve vacuum.
bluedawg357 06-16-2011 09:31 AM
I have 10'' of vac. @ idle in gear, i don't have any issues with my power brakes. you can run a vaccum pump if you do encouter any issues.
hotrod1994 06-16-2011 10:07 AM
ok thanks i dont need to stop on a dime i just need to stop
