-   -   HP EST (https://www.racingjunk.com/forums/showthread.php?t=30554)
ejm 06-14-2011 07:09 PM
HP EST
ok my buddy has a stock 454 (crank, rods, and a little dish piston) with oval port heads with 2.25 int and 1.88 ex valves, bowls blended, and cleaned up a bit, performer rpm intake(not a air gap) and a 850 holley a edelbrock hyd flat tap cam with.560/.573 lift and 240/246 duration (p/n 7162) Any idea for him or me???? thanks guys!!!
blowninjected540 06-15-2011 01:17 AM
Too much Carb for that set-up.
curtisreed 06-15-2011 03:26 AM
350-380ish hp and 400-420ish torque.
Curtis
maxpower671 06-15-2011 08:52 AM
Headers?
Curtis
agree with Curtis' estimates!
you didn't mention the exhaust or headers that are going to be used? good, free flowing exhaust can help a bunch, the tubes wouldn't have to be huge to offer some potential..
ejm 06-15-2011 02:09 PM
yes it will be open headers
bixblk 06-15-2011 02:24 PM
HP ?? guess
I had Joe Ryne do a rebuild very similar to this, awhile ago Mine had approx 10.25 to 1 compression yours might be a little bit
lower but probably close 9 to 1 depending on the dish and CC size of the chamber. (total combustion chamber volume)
anyway with a 750 holley DP it made 402 HP on an engine dyno and similar torque numbers. So it should be in that range probably 375 ish HP.
Mine was a street pump gas motor Sounded great and had good power.
