ls1 cid
What's the max did you can get out of a stock ls1 block?
you can get into the mid 390's... if you want bjgger then that you need to go to the ls2 block :wink: you can build a 408cid iron block for only a few hundred dollars difference but it also weights like 80 pounds more....lol
| All times are GMT -8. The time now is 09:27 PM. |
