-   -   Chevy in a Mustang not fitting, help. (https://www.racingjunk.com/forums/showthread.php?t=30491)
victor400ex 06-01-2011 06:33 PM
I am putting a SBC in a 84' Mustang. I have an AJE Racing Crossmember and Dynatech headers made for the swap, but the steering stem is not working. For one I had to extend it, but that was the easy part. The problem I have now is that the top steering stem knuckle is hitting on the back header tube. Can anyone help me with a solution. I am using the AJE SBC motor mounts also.
Harbone 06-02-2011 06:45 AM
Are you using the stock knuckle? what kind of steering rack do you have?
victor400ex 06-02-2011 04:02 PM
Yes it is the complete stock steering shaft, I just extended it by welding in a piece of shaft so that it would reach.
lively 06-02-2011 05:48 PM
WELL MAYBE A FORD engine :lol: :lol:
fla1976 06-02-2011 05:56 PM
I knew that was coming.:shock: I thought lively would be the one to say it. :lol:
victor400ex 06-02-2011 06:41 PM
Yea, I should have known. But again. I got the SBC cheap. I actually got it for some work I did. Plus I had a mustang with no engine. so I put the two together. It is actually turning out very nice, if I can just get the steering shaft to clear. I am going to try to lower it inside the car tomorrow. If I can, that will fix it.
TheYellaBrick 06-02-2011 08:51 PM
This is what HOT RODDING is all about !! :D :D :D :D Mixing and matching what ya got and making it work !! :D :D :D
fla1976 06-03-2011 02:33 AM
You may have to offset the engine to the passenger side a little bit. The early Camaros with big blocks are offset for the same reason. Easier to accomplish with a motor plate.
Harbone 06-03-2011 04:50 AM
call AJE, I bet the make a custom steering knuckle, also Flaming River makes a nice setup. I had a 460 crammed in a 93 Mustang and the Flaming River knuckle fit like a glove.
lively 06-03-2011 09:58 AM
you can offset the engine a little -just keep it straight in line with the driveshaft---VIBRATIONS can kill ya :lol:
