-   -   cam shaft specs (https://www.racingjunk.com/forums/showthread.php?t=30480)
nutup 05-31-2011 02:10 PM
cam shaft specs
I have a question about cams most gear heads understand lift and duration but what about for example a 900 base circle 108 lobe center what does it all mean to me choosing a cam to fit my application? I have never really understood this I always count on the cam manufacturer I don't know how generic the info they give is don't get me wrong I under stand some just all info together how does it effect each other
fla1976 05-31-2011 03:42 PM
Here is a site that may help with the terminology.
http://www.lunatipower.com/Tech/Cams...fileTerms.aspx
nutup 06-02-2011 01:38 PM
let me ask how does lobe center effect like a 108 lobe center or a 104 lobe center what builds more power with higher compression engines? I know there is a lot more involved but any info is good to have
fla1976 06-02-2011 02:46 PM
Here is another site with more indepth explanation. It is a V-twin site but the information is applicable.
http://www.v-twinforum.com/forums/tw...bers-mean.html
bixblk 06-02-2011 08:01 PM
great info
Those links contain well written info, thanks
nutup 06-03-2011 06:35 PM
thanks that helps a lot that's what i was looking for and it proves one my newest suggested cams is not even close to what results I was after
