-   -   burnout or not (https://www.racingjunk.com/forums/showthread.php?t=30438)
mmphillips 05-24-2011 05:42 PM
burnout or not
im running bfg radial t/a tires on my street car.i want to take it to the track and was wondering will i need to do a burnout or not?
TheYellaBrick 05-24-2011 09:23 PM
Specs of your hot rod, please.
year
make
model
engine size
stock or modified
Also tire size.
Open diff or posi ?
TopspeedLowet 05-25-2011 03:03 AM
No water burnout
Do not do a water burnout with street tires. Most successful street tire racers drive around the water box and do a short tire cleaning in front of the box, that means only about five revolutions or less. Do not heat the tires before the pass, they get greasier with heat.
Bruce
gearhead1011 05-25-2011 08:15 AM
What Bruce said. That and you can't dry out the grooves in a tire with tread.
mmphillips 05-25-2011 05:13 PM
Thanks guys for your help!!
