timing for a 427 chevy small block on alky
Just wondering where you guys have your timing set on your small block chevys on alky . Thanks for any input.
Depending on the cylinder heads. 32 to 36 degrees total.
ALOT of the CHEVY builders around here use Budweiser to set up there engines--ABOUT 3 CASES WILL USUALLY DO IT !!! 8) :lol:
| All times are GMT -8. The time now is 11:11 AM. |
