IS THERE A FORMULA FOR CARB SIZE?
I HAVE A LITTLE MORE COMPRESSION AND A DIFFERNT CAM THAN I HAD LAST YEAR AND THE MOTOR STUTTERS WHEN I LEAVE THE LINE I WAS WONDERING IF I WAS UNDER CARBED.
You can run the basics on a common chart by Holley if I remember correctly. It has been awhile since iv'e done it, but I think it was like cubic inches by max RPM ... then it gives you a starting point. from there, it will help fine tune the size needed.
OOOoooo. nice bunch of formulas !! THANKS !! :D :D :D :D
All the racing math you'll need.
http://www.wallaceracing.com/Calculators.htm BTW Air Capacity & Volumetric Efficiency Theoretical cfm = rpm x displacement / 3456 Volumetric efficiency = actual cfm / theoretical cfm x 100 Street carb cfm = rpm x displacement / 3456 x 0.85 Racing carb cfm = rpm x displacement / 3456 x 1.1 I made some of my own Excel spread sheets for carb. size and for gear ratios and tire speed with any transmission and transfer case / chain drive. |
| All times are GMT -8. The time now is 12:51 AM. |
