-   -   Powder Coating (https://www.racingjunk.com/forums/showthread.php?t=30353)
mouse1972 05-06-2011 07:57 AM
Powder Coating
Hi,
I was thinking of having a set of fender tube headers for my 62 Nova Pro Street powder coated. Has anyone had this done? Do they hold up to the heat?
Thanks.
blowninjected540 05-06-2011 12:42 PM
powder coating does not with stand the heat. You would have to ceramic coat them.
wazup 05-06-2011 03:35 PM
Dont waste your money. Been there done that!
TheYellaBrick 05-06-2011 06:43 PM
http://www.classiccoatings.com/faq.html
http://jet-hot.com/
http://commercialceramic.com/default.aspx
http://www.highperformancepontiac.co...ish/index.html
oldandtired 05-09-2011 05:11 AM
If you are going for looks, ceramic coat them.
Suggestion, make sure you have the your tune up correct before sending them off. I have ruined a new set by running too lean on start up.
ajk 05-10-2011 02:14 PM
Check out jethot coating never had a issue....
gearhead1011 05-10-2011 06:28 PM
I have had issues with Jet Hot and won't use them again. I've heard nothing but good stuff about Nitro Plate. They have a black coating that is good for something like 400* more than the silver stuff. I have been told the silver coating temp rating is limited by the aluminum in it and none of the silvers hold up above 1300*.
dcsquare 05-14-2011 12:23 PM
I used jet hot and was not pleased after the first year. This time I used a company in Troy, Ohio called Aesthetic Finishers www.afipowder.com.. Took a pair of older upswepts that I thought I was wasting money to finish and they came out better than I expected. Great company and friendlystaff. They do alot of show car stuff and much more reasonable than others.
Ron612 05-28-2011 07:01 PM
Rust-oleum in a spray can
if you what to save your $$$, try Rust-oleum in a spray can good for 1200F Tough protective for grills, stoves, & Radiators, i've used it on headers for years never had a problem, you can fined it at your local Home Depot or Lowe's
ashtrak 07-01-2011 06:19 AM
Ceramic coated inside as much as possible and out good for 1600 degrees
http://i563.photobucket.com/albums/s...2/IMGP0596.jpg
http://i563.photobucket.com/albums/s...2/IMGP0595.jpg
http://i563.photobucket.com/albums/s...2/IMGP0593.jpg[/img]
