-   -   Adjusting the floats (https://www.racingjunk.com/forums/showthread.php?t=30284)
sirswapsalot 04-23-2011 02:01 PM
i have a 406 sbc with a 850 quick fuel carb, i got the floats set 1/2 (middle)
of the sight glass.
should it be set higher to the top (so when u shake the car, u then see the bubble) ???
i know 1/2 way would be ok on a street car but this is a race car only
where do u guys set yours, thanks for the help.
fla1976 04-23-2011 02:13 PM
Remove plug and adjust so fuel is at bottom where it just barely starts to leak out.
curtisreed 04-23-2011 05:46 PM
Sight glass so no plugs. Is this gas or alcohol?
Curtis
sirswapsalot 04-23-2011 07:04 PM
its gas & has the clear sight plugs......
curtisreed 04-24-2011 05:08 AM
If it is not pulling fuel over into the boosters at idle you should be fine.
