blower and nitrous anybody running it
i have a 871 blown 509 bbc dart block good bottem end.i have purchased a nos blower kit,currently running c-16 fuel,i am going to spray about 100 hp,other than the normal take out timing colder plugs atc any other advice.this is in a drag car makes about 15 psi boost.
JUST HANG ON TUNE AFTER RUN IT SHUULD IMPRESS YOU ARE YOU OVER OR UNDER DRIVEING THE BLOWER :?: :?: :?:
20 % over
Could be hard too tune, why don't you just switch to alcohol nozzles. You get the benifit of cheaper fuel (by a bunch) and will be much easier to tune and probably more power than a 100 shot on gas.
JMO Zip. |
| All times are GMT -8. The time now is 09:15 AM. |
