-   -   AFTERMARKET STEERING (https://www.racingjunk.com/forums/showthread.php?t=30204)
JEFF69Z28 04-07-2011 08:10 AM
WILL A GRADE 8 1/4 INCH BOLT BE GOOD ENOUGH TO HOLD THE STEERING KNUCKLE TO THE STEERING SHAFT,STEERING ASSMEBLY IS CHROME MOLY. :?:
johnracer 04-08-2011 02:49 AM
You'll need to clarify exactly where this bolt is going. The ONLY place I'd use a 1/4" bolt on the steering would be to retain the u-joint to the shaft or the shaft to the gear....the knuckle thing has me confused.....easy to do by the way
Johnny
TheRabbit 04-08-2011 06:58 AM
Johnny
I was thinking the same thing. Wasn't sure what he was asking.
If it's any help I sure hope a grade 8, 1/4"bolt is good enough to hold the steering shafts together because that's what I use.
JEFF69Z28 04-08-2011 08:41 AM
Johnny
[img]AFTERMARKET STEERING COMES THRU FIREWALL ATTACHES TO U JOINTTHEN TO SHAFT THEN TO U JOINT ON MANUAL BOX,THE OTHER JOINTS ARE TO BE TIG WELDED[/img]
TheYellaBrick 04-08-2011 03:58 PM
pic didn't show !
TheRabbit 04-09-2011 05:44 AM
http://i163.photobucket.com/albums/t...8/Steering.jpg
Is this what you're asking?
