-   -   QA1 Double adjustable shocks for rear (https://www.racingjunk.com/forums/showthread.php?t=30179)
rhino502 04-03-2011 10:34 AM
I have installed a pair on my drag car and looking for a starting ponit....Car is a 70 nova with 540 aprox 800 hp and around 3400 lbs with driver...ladder bar setup, transbrake...rear weighs 1740#..i have 170# springs...if anyone is running these shocks any help appreciated..thanks
TheRabbit 04-12-2011 05:21 AM
Since nobody has replied yet. I run the same shocks. Personally I think the 170lb springs are too stiff. My truck is 2,800lbs and even the 150lb springs unload the rear after about 100' feet. (I'm over 1,220hp.) I run 110's.
But to answer your question a lot depends how hard you launch. I would start with compression and rebound half way and go from there. Every vehicle is different so it's gonna be trial and error for a few passes.
zipper06 04-12-2011 05:54 AM
X2 on the springs being too heavy, my car weighs 3250 lbs with a 4 link setup, and i run 130 lb springs with the QA1's. I don't remember the scaled rear weight, but it was somewhere near your's, with a sm/blk in my car.
