-   -   msd question (https://www.racingjunk.com/forums/showthread.php?t=30135)
john910 03-28-2011 12:03 PM
msd question
i'm runing a msd 6AL and msd coil. when i turn on the ignition before i start the engine should i get 12 volts to the pos. side of the coil? don't remember. we are ready to start motor and break in the new cam and i want to be ready and have it fire up as soon as possible. just checking. thanks john sullivan.
fast75vega 03-28-2011 01:33 PM
yes.... you should have 12 volts at the coil with key on
wmeabates 03-28-2011 03:58 PM
John,The coil + will only get voltage from the MSD when the MSD box gets a trigger from the dist.or crank trigger.Don't check for voltage at the coil it's going to be 400 volts or more when cranking.You should have 12 volts all the time at the big red wire and 12 volts at the small red wire with the ign.switch on.Bill.
john910 03-28-2011 05:24 PM
msd question
so with the ignition swicht turned on and not turning motor over with starter button should i be able to read 12 volts at the coil?
wmeabates 03-29-2011 04:10 AM
No.
john910 03-29-2011 06:15 AM
msd
ok i called msd they told me i will not have a 12v reading at coil. thanks for all your help. john s.
fast75vega 03-29-2011 06:51 AM
Re: msd
they are right.... i just checked mine and nothing.......lol
john910 03-29-2011 08:23 AM
msd
thanks guys,never hurts to ask. john
