-   -   9375-2 CARB (https://www.racingjunk.com/forums/showthread.php?t=30086)
RAPPTOR23 03-20-2011 05:30 AM
9375-2 CARB
HOW CAN I TELL IF THIS IS AN --HP MODEL>>?? NEED TO CHANGE BOOSTERS .# :shock: 9375-2??
mopar1968 03-20-2011 07:09 AM
This is from jegs.com
510-0-9375-2BK
Ultra Dominator Carburetor
1050CFM
3-Circuit
2 x 4 Carb Set-Ups
Black
View this item
510-0-9375-2RD
1050CFM
3-Circuit
2 x 4 Carb Set-Ups
Red
It isn't a hp model :!:
Mark
markdunlap 03-20-2011 07:58 AM
9375-2
I thought HP is the new style casting verus the original style dominator in which case they look quite different. The HP series are all that have been made for several years and anything sold new by Jegs will be HP. Correct me if I am wrong.
I have used the 9375 with the annular boosters on single carb BBC applications with just air bleed changes. They do tend to go a little rich on top end though in 1/4 mile.
The Ultra series is just billet metering blocks added and some updates.
jmarksdragster 03-21-2011 12:26 PM
Yes that should be an HP carb. What is wrong with the boosters? www.blp.com has booster banjo's, stock or modified cast inserts as well as billet inserts and booster pins. Gaskets, screws, etc, anything else you need to rebuild one.
mopar1968 03-21-2011 12:37 PM
It depend's on how old the carb is if it is a HP or not :!: I agree the one's they sell now are all HP's :!: I have two 9375's and they are around 10 years old but they aren't HP's :!: Just standard Dominator's :!:
Mark
