trans cooler lines
I'm looking for trans cooler lines for a 1994 gmc c1500 but all i can find is just rubber hoses. right now it has metal lines that screw in at each end. I was hoping to get exact replacements to just screw in, does anyone know where to get them? or any alternatives to replacing the lines? I hit a tree and both lines busted in the middle of the lines.
Does the engine make a difference with the lines, because when I put the engine info in (4.3L v6) none of those lines are available?
You should be able to get these new or get some from a junk yard atleast. If you can go buy some new 1/4" steel line at ur local auto part store, then bend and flare them to fit. Seach craigslist for someone parting out a 88-95 chevy truck. No they can go either way, one on top or bottom
| All times are GMT -8. The time now is 09:04 AM. |
