Crankcase evac
Do I need a evac system on a bb chevy normally aspirated?
You need some type of evac on any engine. Wether you use a vacuum pump or header evac system or even a pcv valve the crank case has to be ventilated.
TS1955 |
Kinda the rule of thumb, if you have mufflers you will need a PVC system, if you run open headers you will need a header evac or vacuum pump.
JMO Zip. |
you cant run a header evac set up if your running mufflers?
Been there and done that. Zip. |
| All times are GMT -8. The time now is 09:15 AM. |
