-   -   Why do they (https://www.racingjunk.com/forums/showthread.php?t=29874)
Goomba 02-16-2011 05:23 PM
Why do they
Why do they put wide white stripe on there slicks? Like in add 2131806 . :?
TS1955 02-16-2011 05:35 PM
It's alot easier to see wheel spin.
TS1955
lively 02-16-2011 05:36 PM
IT HELPS TO CHECK FOR TWISTING OF THE SIDEWALLS AT LAUNCH AND WHILE GOING DOWN TRACK --I WAS TAUGHT
you can use a camaro to see the movement in slowmochine .
WE ALSO PAINTED A MARK ON THE RIM WHERE IT TOUCHED THE TIRE TO CHECK FOR SLICK MOVEMENT AROUND THE RIMS DURING LAUNCH
Goomba 02-16-2011 05:42 PM
you can use a camera to see the movement in slowmochine .
Thanks guys. I always was wonderinng that but never ask. :wink:
Harbone 02-17-2011 04:33 AM
Its cool to watch the launch on Fuel cars when they play it back in hi-def slow motion, the abuse those tires take is incredible!
itsabird 02-17-2011 05:18 AM
Almost a must, for making chassis adjustments. good one with the camaro thing lively, i will use that one on my ford pals. :lol:
ccperf721p 02-17-2011 07:39 AM
You don't need the stripe on a Ford. If you can't read the letters on the sidewall it means he's in the burnout or driving through his own oil.
fast75vega 02-17-2011 08:29 AM
lmao..... very well said :lol:
itsabird 02-17-2011 09:03 AM
in otherword watch the valve stems. :)
dpassmore 02-19-2011 06:55 PM
You're right the camaro works perfect. Just look out the driver window of your mustang and you'll see the camaro's rear tire.
