-   -   400SBC ??? STROKER KITS (https://www.racingjunk.com/forums/showthread.php?t=29869)
lively 02-15-2011 08:13 PM
LET'S SEE--i have come up with a 400sbc --2 BOLT MAINS--in trades 8)
my son has a 91 S10/ and a nice overdrive trans/ and just happen to have a narrowed 9 inch :roll:
anyway-- he has built a nice 350 engine for it but now i have this 400[ STROKER KITS??] :? 8)
GOOD/ BAD / UGLY??? :lol:
you chance to convert me !!!! :lol: :lol:
dragonmaster093 02-15-2011 11:05 PM
400s a good motor but have a unique head wirh steam ports an need 400 specific gasket you can stroke it or just build a nice 406
zipper06 02-16-2011 08:45 PM
Since it is appearently for street use (IE OD trans)i'd stick with the 350 which he already has built. 400's are tricky and sometime run hot on the street, plus they are notoriously thin on the cyliner walls and have to be checked for wall thickness before ever boring the blk.
dragonmaster093 02-17-2011 07:46 PM
or punch 350 to 355 clearence block and 400 crank and rods and have old school 383 stoker and resell the 400 block
BEAST477 02-18-2011 02:07 AM
Sam are you saying put the 400 crank in the 350 block? Aren't the mains journals larger on a 400 crank than a 350?
MEMRACING62 02-18-2011 02:45 AM
HUH.... :? :? NO, YOU NEED A STROKER CRANK! :roll:
mopar1968 02-18-2011 04:51 AM
Shoot guy's you can make that 400 crank fit the 350 block with a BIG hammer :!: :!: His uncle could make a 454 crank work :!: :!:
Mark
MEMRACING62 02-18-2011 10:53 AM
Mark
It has been rumored that there is three wise engine builders in southern virginia that can preform this task with great skill :shock: :shock: :P
mopar1968 02-18-2011 12:23 PM
And i thought there was only 1 that moved here :!: :shock: :shock:
Mark
MEMRACING62 02-18-2011 12:37 PM
NOTICE TO ALL BUILDERS...A STROKER KIT IS NOT...A JAR OF VASELINE & A PENTHOUSE ! :shock:
