-   -   engine oil (https://www.racingjunk.com/forums/showthread.php?t=29788)
taps 02-04-2011 11:13 AM
engine oil
i have a blown gas 509 chevy drag car what is a good oil to run.
TS1955 02-04-2011 11:53 AM
You'll probably get alot of answers on this one.
There is:
1 Brad Penn (really good with alcohol)
2 Schaeffer (this is what I use)
3 Pennsoil Racing oil
4 Valvoline Racing oil
5 Joe Gibbs Racing oil
All of these are good oils so take your pick.
Just use a good filter!!!
TS1955
spib 02-04-2011 12:28 PM
I use brad penn 20-50 and a k&n filter on my good motor
fast75vega 02-04-2011 01:28 PM
i like castro 20/50 or kendall 20/50
lanham 02-04-2011 02:22 PM
I use Brad Penn 20/50.
kwkracing 02-04-2011 08:05 PM
I run half valvoline and rotella diesel oil with a cup of marvel mystery oil in all of my blown engines. The viscocity varies, but usually a straight weight 50 or 60. All my blown engines have the clearances on the loose side.
JEFF69Z28 02-08-2011 02:18 AM
X2 BUT ADD A LITTLE VIRGIN OLIVE OIL INTO THE MIX....LOL
hammertime 02-08-2011 05:38 AM
VR1 or Shaffer for me
You guys who run Brad Penn and Rotella, know they changed the oil in the last year and its nothing like it used to be with far less zinc and phosphate content now.
markdunlap 02-08-2011 03:37 PM
Engine oil
I know they had to change any oil that is for consumer use as in Walmart and auto parts stores.
But I talked to the Brad Penn Oil Company directly with in the last 6 months and they state the ZDDP and other antiwear properties we need are unchanged because it is racing oil only.
In any case I am glad I stocked up on Brad 20-50 back when it was $25 a case.
hammertime 02-08-2011 06:14 PM
Oil test results show different answers on them not changing it :shock:
