-   -   PRO cylinder head guys HELP!!!!! (https://www.racingjunk.com/forums/showthread.php?t=29711)
vegabond 01-26-2011 02:24 PM
I need some help on some SBC heads(sb2.2, 18 degree) both styles of heads are getting cracks in between the center 2 chambers i.e. (between the 2 siamese exhaust vavles). Is it because of the steam holes that are drilled parrelle to the deck between the outer water jacket and the inner one(there on bowtie blocks which are siamese cylinders)? If i grind them out and weld the cracks up do i need to redrill the steam passage? Just didn't know if the heads would be O K without that passage? Thanks in advance for the help---Steve
bluedawg357 01-27-2011 06:28 PM
If it were me & I was welding up the heads I'd redrill the steam holes. What kind of heads are they? The manufacturer would know best there, & if they ain't to old maybe they'd discount a new set of heads.
