SBC spun cam bearing
I have a sbc 350 engine that is currently set up to run mid 12's it lost a little oil pressure the last time it was ran so we pulled it apart and found out that it has spun a cam bearing. My question is can this be fixed? the block has had a lot of machine work done to it and everything looks good except for the cam bearing problem.
Re: SBC spun cam bearing
They offer over size cam bearings up to .040 over on the housing bore ID Which cam bearings Clevite??????? |
I would have to look to make sure but I think it is the # 3 bearing and yes we were using Clevite bearings.
What bearings would you recomend to go back with? |
What bearings would you recomend to go back with? We keep the ACL .010 over bearing P/N 5C004AS-STD on the shelf we like them over the Babbit bearings, You can also go with the Durabond performance cam bearings as well. Good luck |
Since you have to pay for the set up and boring job, why not spring for the roller bearings?
The more common size we do on the OEM blocks is go to the BBC cam tunnel which is .021 smaller then the 50MM cam journal and there is more power to be made with a babbit bearing over using roller cam bearings. |
| All times are GMT -8. The time now is 08:30 AM. |
