-   -   egt probes (https://www.racingjunk.com/forums/showthread.php?t=29680)
dcsquare 01-23-2011 08:46 AM
egt probes
The dragster I have has an altronics "informer" in it . I am trying to find the compression fittings for the egt sensors. They have a 7/16-24 male thread above the compression ring and need to go to an 1/8 pipe thread weld in bung. Apparently the guy left the bottom part of the compression fitting in his headers, now they are gone. Anybody know where i can find these type of fittings?
markdunlap 01-24-2011 06:30 PM
EGT
Go to the hardware store and check out 1/8" copper tubing compression fittings.
dcsquare 01-25-2011 01:12 AM
won't work those have a compression NUT, this is like a compression BOLT. Looks like a Honeywell gas orafice fitting.
482 01-25-2011 04:15 PM
Did you call Altronics? 1-888-464-2587
dcsquare 01-26-2011 02:29 PM
Yes. Don't not make it anymore. Would have to special order and for the price they charged me for the compression fitting they use now (which is of the "$1.50 hardware store" variety::::"nut and ferrel") I do not want to special order...I was hoping it would be the version they used before. Don't get me wrong they have been very helpful with the outdated unit. Will look in MSC or McMaster Carr. thanks!!!!
gearhead1011 01-26-2011 07:45 PM
Can you just cut off the existing ferrule and replace it with the newer style? I would try using a small grinder or die grinder and carefully cut through the ferrule.
dcsquare 01-28-2011 03:30 PM
Possible but not what I wanted to do . Bolt on!!!!
