-   -   fuel pump and line help (https://www.racingjunk.com/forums/showthread.php?t=29651)
bigmack 01-19-2011 12:09 PM
need help with set up, i pick up a new car 87 camaro it have -10 fuel line from rear to front it goes to the regulator to cool can to crab. it doesn't have a fuel pump and this is where i need help with. i'll be running around a 500 to 550 sbc do i need to change this fuel line or can i just buy a fuel pump to work with this large fuel line set up. thanks for your help.
TheRabbit 01-19-2011 02:41 PM
A little more info will help. Is this a street driven car or drag only? IMO the #10 is too big. #8 is all you need to the reg. then run #6 to the carb.
You can run the #10 since it's there, but it's just way more than you need.
About the pump. If you running on the street I'm not sure what the best is, but for the strip get a simple Areomotive pump will be fine.
http://aeromotiveinc.com/products-pa...l-pump-38-npt/
Do NOT get a Barry Grant pump. I assure you, you will regret it if you do.
If you drive it on the road the other guys will give you some better advise on that.
bigmack 01-19-2011 02:53 PM
sorry it's a drag only car.
