-   -   need a little advise (https://www.racingjunk.com/forums/showthread.php?t=29637)
fast75vega 01-18-2011 05:43 AM
i got a 406 sbc putting out 780hp at the flywheel..... my motor has a belt drive now but always like the sound of the noisy gear drives...... anyone ever run one and which is better(do you lose or gain hp with it and which is more durable....ect) thanks, chuck
johnracer 01-18-2011 10:49 AM
Don't do it!! Stick with your belt drive. Why go backwards?
Johnny
TS1955 01-18-2011 11:23 AM
Johnny
X2
TS1955
TopspeedLowet 01-18-2011 12:03 PM
Hope you have a sense of humor
Gear drives transfer harmonics from the crank to the cam and valve train and usually require drilling of the front main cap and or machining for fit up to the block as well.
I might suggest that you record the SOUND of some other racers blower during a burn out and put it on your I- pod (or something like that), then listen to it whenever your engine is running if it makes you happier, but if you want to go fast with less moving parts, stay with today's technology and use the belt drive.
Bruce
fast75vega 01-18-2011 01:36 PM
cool ... that answers my question.....thank guys :)
i love the ipod idea......lmao :lol:
itsabird 01-18-2011 02:17 PM
I have seen more belt drives, than i have heard gear drives lately, if that helps any.
oldandtired 01-20-2011 06:38 AM
Re: Hope you have a sense of humor
Originally Posted by TopspeedLowet
Gear drives transfer harmonics from the crank to the cam and valve train Bruce
x2 should not run with cast crank or cast cam.
dragonmaster093 01-20-2011 04:57 PM
on the same subject kinda how about gear drive for street car no real high revs maybe once and a while tip to track (street fights)
SABOT7 01-26-2011 11:43 AM
Most gear drives I've heard sound like a powersterring pump ready to take a vaction!
