-   -   which system is better a 12volt or 16 volt (https://www.racingjunk.com/forums/showthread.php?t=29621)
rhiasdaddy 01-16-2011 05:10 PM
trying to figure which electrical system to run in my race truck so which is better 12 or 16
BEAST477 01-16-2011 05:45 PM
Can you give a little more info? How many cubic inches are you trying to start? What compression ratio? How much other stuff are you going to run? Will you run an altenator? Is this a new build are you starting with no elec. parts?
TheRabbit 01-17-2011 08:26 AM
Yep I agree with Beast. No need to spend that kind of $ if you don't need it.
But if you have a high compression motor, no alt. 16 volt is the way to go! I run everything 16 volt. fan, water pump and fuel pump.
