-   -   gear ratio (https://www.racingjunk.com/forums/showthread.php?t=29617)
scott0408 01-16-2011 02:22 PM
gear ratio
i am going to change engines from a 355 to a 421,i have a choise of rear gears,456 or 486,car weighs 2780,power glide trans 14-32 tires.
zipper06 01-16-2011 02:58 PM
I'm assuming you're running 1/8 mi only. I think the 4.86 would be quicker, but if you're also running 1/4 mi, you might be twisting the 421 a little tight.
SABOT7 01-26-2011 12:17 PM
I agree with zipper. the 4.56 would be a gear that you could run both 1/8 and 1/4 without issue. However, if your mostly 1/8 mile go with the 4.86.
maxpower671 01-28-2011 07:32 AM
RPM formula
this is an easy formula that seems to work....
MPH x Gear Ratio x 336 divided by Tire Diameter(inches)
say 100 mph, 4.86 gears, 30" tires.....= 5443 RPM
if you want to get fancy, you can add an inch or whatever for Tire growth, and add 5-10% for convertor slippage.....anyways, it works!
