-   -   to poly or not to poly? (https://www.racingjunk.com/forums/showthread.php?t=29574)
bigpapparacing 01-10-2011 06:15 PM
I am currently building a 29 model A rat rod.I was planning on running a 302 and a C4. My friend has a 55 dodge royal im planning on buying also to fix as a rat rod.anyway, it has the original polyspherical engine in it.I have never heard of one until now.my question is, should I put the poly in my 29 and be different and cool or keep the 2 dr. hrd. top royal an original numbers matching car even if im not planning on doing a full restoration on it.both cars will be pretty much daily drivers.
dragonmaster093 01-10-2011 06:36 PM
id say keep the dodge original if collector ever bought it from ya stand to make more off it but thats my personal opinion
mopar1968 01-10-2011 07:22 PM
I agree if the body is in good shape keep it in it :!: :!:
Mark
bigpapparacing 01-11-2011 05:57 AM
That was my original opion to, but then I got researching about the little poly and thought it would be cool to use as a period correct engine swap as so many hot rodders did in the, 50's.I think I will keep the dodge original though and see if maybe I can find just a poly engine somewhere.thanks guys.I still would like to hear more from others though.i'd really like to know of the poly's performance potential?
TheYellaBrick 01-11-2011 08:34 AM
The 'performance potential' is very minimal as it was not designed with 'performance' in mind. Besides there is almost ZERO hi po parts available. Your basic camgrind can be had from any grinder, heads can be opened up and 'blue printing' the rotating mass and block is about all you can do. I don't even recall seeing any sort of aftermarket intake manifolds offered for it ! It would all certainly go under the 'period correct' heading as it is all basic hotrodding engine preparation. Try to find a builder that is either still running or has NOT been exposed to the elements( can still rotate) as the pistons could be frozen in the cylinders.
bigpapparacing 01-12-2011 06:44 AM
I keep reading that you can use the newer engine cranks and rods and even striker assemblies in them? Has anyone else heard or read this bit of info? If I can that to me seem like performance potential in itself. As they have always crammed the saying " their are no substitution for cubic inches " down my throat.lol.
TheYellaBrick 01-12-2011 07:09 AM
http://www.camcraftcams.com/archive/...rysler-318.htm
TheRabbit 01-12-2011 02:30 PM
There is a substitution for cubic inches. It comes in a bottle. lol
dragonmaster093 01-12-2011 05:22 PM
or turbo or super charger ect
bigpapparacing 01-14-2011 05:11 AM
Lol.yea that's one reason why I was trying to find out about the newer stroker kits so I find some forged guts for it. Then put a procharger on it, and see how the old gal will scoot.
