-   -   what engine temp before run? (https://www.racingjunk.com/forums/showthread.php?t=29564)
deepockets 01-09-2011 06:25 PM
what's a good engine temp to run when you pull up to the burnout box?
mopar1968 01-09-2011 06:35 PM
I let mine get up to 180 to 190 :!:
Mark
chevyfireball 01-10-2011 06:03 PM
BBC. Mines usually about 120-130 before the burnout and about 160-180 afterwards. If its only 160 before the run I leave the fans off til the end of the strip to lower the amp draw. Gets to about 190-200 without the fans.
TS1955 01-11-2011 06:20 AM
I'm particular with temperature. I pull out of the staging lanes at 160. I'll bring it up to 170 to start my burn out. Then I stage at 180. I feel that the more consistant you keep things, each run will be more consistant. JMO.
TS1955
TheRabbit 01-11-2011 10:36 AM
Of course I don't do burnouts, but I stage mine at at least 160, but like to be at 170. Some motors run better cooler, but mine runs like a turd if it's colder than 160. I do run the water pump, but do not run the fan until I hit the finish line.
lanham 01-11-2011 03:21 PM
X2
duswill 01-17-2011 06:51 AM
My small block likes about 160-70
maxpower671 01-17-2011 09:16 AM
Engine Temp
X2
X3!
SABOT7 01-26-2011 11:55 AM
Gas or Alcohol?
shawnp 01-27-2011 05:36 AM
Rupert Alky Carb on BBC. On the morning warm up I push the car to 200. Shut it off and turn off the water pump to let the heat soak in. When I head for the lanes, 150 degrees. I like to be 160 going into the water and that normally has me 165-170 depending on the time of the year staging the car. Car back at that trailer never above 180.
