afr heads
Im building a 400sbc it .30 over setup for 11-11.5:1 comp turning 6700-7000rpm now i found a good deal on afr heads except there 195cc runner wit 2.05/1.60 would that be too small to feed the 400 or not ive seen decent dyno sheets bringing 560hp at the fylwheel but i want more towards 600 would it be reachable with those heads
IT DEPENDS ON WHAT SIZE A CAM YOU HAVE ALSO.I HAVE 210 AFR HEADS CNC'ED 208/160 I TWIST 7200RPM OUT OF MY 406.OTHERS ON HERE KNOW MORE IM SURE YOU WILL GET MORE AWNSERS SOON.
AFR and most head mfrs would probably tell you these are too small for your application. AFR suggests 180 runners for 327-350 small blocks and 195 for 383-400 motors, but for street motors. You might be able to get by if the heads are heavily ported. I think they will run out of air on top end. I am running a set of 180 AFRs on a 406 but only because they were on a 355 and my car totalled in a fire. Check out AFR's website. I found their tech line very good. Great heads. Good luck. Mep
If your going to be using a hydraulic roller cam, the 195 heads will be a great fit. The 195 heads are capable of making 600 hp
Afr heads are damn good, I have 210 cnc heads on a 385 but its drag only
motor turns 7500 at the traps and its 13.2to1 compression |
Re: afr heads
| All times are GMT -8. The time now is 06:57 AM. |
