ignition problem???
have a ticking noise on number 7 cylinder.Pulled plug wire of at plug noise goes away.pulled plug wire off at cap noise goes away.put new plug wire on noise still there.Put new MSD Cap and rotor on noise still there.took plug wire off again noise gone.Took number 1 plug wire off noise still there.changed plug noise still there.Made sure I have no exhaust leaks either before I started with the ignition.
Is it just a light ticking? I know when a rod is making racket you can often pull the plug wire and quiet it down some because the load is gone on that cylinder. SORRY CAN'T HELP YOU ON THE IGNITION
yes it is just a light ticking.like a small exhaust leak.I didnt even think it could be rod related.Thanks.
can a rod knock really sound like a ticking noise...hope its not,its a fresh motor.
Might be starting on that new motor sooner than i thought.
Year make model of engine please.
Headers or cast iron exhaust ? |
headers,its a 355 sbc,MSD HEI IGNITION.
not sure on the year but it is an 010 block.
With the engine at an idle, take a breaker bar or chunk of solid steel rod, put one end against your ear and the other upon various locations around each cylinder, on the head, valve cover, and header. I've successfully used this method of isolating noises for years. It's a cheap but effective 'stethoscope'.
| All times are GMT -8. The time now is 03:31 AM. |
