chuck nuytten 75/25 1350 cfm trying to decide
im trying decide if running 25% alcohol is going to cause me a lot of work on my fuel sytem, i run magna fuel 500 and regulater, and thinking of having nuyten build me a 75/25 1350 cfm carb. any one have advise?
Your pump will be fine, and a -10 to the regulator and -8 to the bowls should work well. Larger lines are o.k. if you've already got them, you just wouldn't want to go smaller. You'll need a blending agent to keep the methanol and gas mixed. I've done a lot of them, call if you have questions. 417-859-2353
| All times are GMT -8. The time now is 08:06 AM. |
