-   -   40 amp mini alternator (https://www.racingjunk.com/forums/showthread.php?t=29316)
ballsout1 11-30-2010 05:53 PM
i got a mini alternator that i did up 1 wire and mounted low in my chevette. anyways its gonna be a limited street/ track car. i`ve got a electric fan, msd, fuel pump, and my lights/directionals. i`ve got a optima battery . car might see 30 miles a week on the street. whats the thoughts on running only a 40 amp alternator.....its small, light...cool.. maybe trouble.
chevyart 11-30-2010 06:14 PM
mini altenator
who makes it or what car is it from. also what bracket setup did you use to mount it and where did you mount it thanks art
ballsout1 12-01-2010 05:23 PM
i gotta laugh a bit..its off a fork truck. i think its gm based. i`ve got a fabbed up bracket on the power steering boss holes and i have a chrome , large, semi horshoe adjustable arm that was meant to be used on a top mount set up in 1 original alternator boss in the head....looks a little odd first glance but the traditional low mount you buy wont fit my chassis. anyways.. i`m a little concerned if i take it to some cruise nites with no charge in between... 40 amps i would think should run ignition, fan, pump, and lights.
zipper06 12-01-2010 07:46 PM
not enough, you need an 85 amp 1 wire GM.
ImBack 12-14-2010 05:45 PM
I have a 35a Nippensdenso off a Toyota forklift on mine.
