-   -   2 QUESTIONS ABOUT SBC (https://www.racingjunk.com/forums/showthread.php?t=29310)
JEFF69Z28 11-30-2010 03:36 AM
WHAT DOES A SBC MOTOR WITH ALUM.HEADS WEIGH?
WHAT SIZE BOLTS SHOULD I USE TO BOLT IT TO A ENGINE STAND?
Tod74 11-30-2010 08:01 AM
DON'T KNOW ABOUT THE WEIGHT. A STOCK SBC WITH IRON HEADS AND INTake is about 675 lbs.
Use 3/8 bolts to mount it to the engine stand...what else could you use? :? The bell bolts are 3/8-16 so that's what you use.
