-   -   18 Degree Intake vs 23 Degree (https://www.racingjunk.com/forums/showthread.php?t=28980)
jreiley 10-07-2010 08:02 AM
I'm rebuilding my sbc race engine from the ground up. I will be replacing the heads, intake, valve train, etc. Would going to a 18degree top end make sense? I'm shooting for 700hp.
TS1955 10-07-2010 09:34 AM
With the right components you can get 700hp from a 23 deg motor.
TS1955
curtisreed 10-07-2010 09:38 AM
But not as easy as from a 18° motor. We have a 406 that made 705hp with 23° heads and it has had quite a bit of port work on the heads and intake, 15-1 compression on alcohol, with a pretty aggressive cam.
Curtis
jreiley 10-07-2010 10:09 AM
If the dollars are basically the same to buy a new top end, I would think the 18degree is the way to go.
ccperf721p 10-07-2010 10:29 AM
If you are already planning on spending the money, might want to consider a 15 degree setup.
jreiley 10-07-2010 11:29 AM
Don't the 12,15 and 18 degree heads use the same intake and exhaust.
cncmotorsports 10-07-2010 01:51 PM
12, 15 and 18 degree take the same intake
700 HP is easy with either 23 degree or 18 degree
zipper06 10-07-2010 07:08 PM
I respectfully disagree, it's not easy to make 700 HP with 23* heads without spending a ton of money. (why don't you tell us how much you get for a 23* head motor making 700 HP guarenteed/dyno'ed. without additaves/nitrous) Exceptionly/good 23* heads flow maybe 340 CFM. Good 18* heads flow 400 CFM plus, with a 434" it's possible to make 800HP plus with 18* heads for less than $10,000.00 without additaves,
Carb to pan.
curtisreed 10-08-2010 03:18 AM
I'm with Zip on this. 700hp with 23° heads is not "easy". If it were that easy for you guys I would be seeing a lot of CNCmotorsports sbc motors out there, because you guys could sell them cheap, and hearing a lot of buzz about them. Or at the very least you would be selling quite a few of those 23° heads you are using to do it. Not saying it can't be done just saying it ain't easy.
Curtis
jreiley 10-08-2010 04:44 AM
Pretty much decided to go the 15/18 route. Not being totally sure what I need to look for other than heads and intake, what else special do I need to look for?
