picking a cam
ok my set up is a basically stock efi chevy 350 and ive heard that once you get into the past a 501 cam the fuel injector wont pump enough fuel to keep the motor at an idle true any suggestions on cams would be nice
What efi set up?
stock efi also
tbi? multi port? chevy ? ford?
tbi chevy wanting to run a 511 cam but friends say it wont stay idiling and die due to lack of fuel
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 3,000-6,500 Intake Duration at 050 inch Lift 234 Exhaust Duration at 050 inch Lift 244 Duration at 050 inch Lift 234 int./244 exh. Advertised Intake Duration 292 Advertised Exhaust Duration 302 Advertised Duration 292 int./302 exh. Intake Valve Lift with Factory Rocker Arm Ratio 0.488 in. Exhaust Valve Lift with Factory Rocker Arm Ratio 0.510 in. Valve Lift with Factory Rocker Arm Ratio 0.488 int./0.510 exh. Lobe Separation (degrees) 114 Computer-Controlled Compatible No Lifters Included Yes Lifter Style Hydraulic flat tappet Valve Springs Included No Retainers Included No Locks Included No Valve Stem Seals Included No Timing Chain and Gears Included No Assembly Lubricant Included Yes Pushrods Included No Rocker Arms Included No Gaskets Included No cam specs too big??? |
IMO> it wont work........ TBI's dont have much of a tuning window as it is, now if you had port injection, yes but with that the old TBI set up of yester-year, your pretty much stuck to a RV cam at the most.
Basic Operating RPM Range 3,000-6,500 Intake Duration at 050 inch Lift 234 Exhaust Duration at 050 inch Lift 244 Duration at 050 inch Lift 234 int./244 exh. Advertised Intake Duration 292 Advertised Exhaust Duration 302 Advertised Duration 292 int./302 exh. Intake Valve Lift with Factory Rocker Arm Ratio 0.488 in. Exhaust Valve Lift with Factory Rocker Arm Ratio 0.510 in. Valve Lift with Factory Rocker Arm Ratio 0.488 int./0.510 exh. Lobe Separation (degrees) 114 Computer-Controlled Compatible No Lifters Included Yes Lifter Style Hydraulic flat tappet Valve Springs Included No Retainers Included No Locks Included No Valve Stem Seals Included No Timing Chain and Gears Included No Assembly Lubricant Included Yes Pushrods Included No Rocker Arms Included No Gaskets Included No cam specs too big??? " Computer-Controlled Compatible No " |
ok well if i swapped the tbi over to carbaurated would it work and main reason i want the bigger cam is for the lopey idle im going to sell it when im done and lopeyer the idle the "meaner" it sounds
Computer-Controlled Compatible No Tbi's are not performance friendly. A nice exhaust will give it a good sound and save you lots of money and headache.[/quote] |
| All times are GMT -8. The time now is 12:15 AM. |
