-   -   Trailer Modification Regulation Question (https://www.racingjunk.com/forums/showthread.php?t=28940)
rreffects 09-30-2010 10:37 AM
Hey Guys,
I'm hoping someone here can point me in the right direction. We are modifying a 48' semi-trailer as our mobile shop. We've got the lift gate, and the jockey boxes installed.
I'm now installing a generator in the Jockey boxes. It will be vented, and situated so it can be pulled out when ran etc. The trouble I'm having is I need to install a fuel tank for it.
One of the jockey boxes at the rear of the trailer is perfect for it. It's a shallow box, mainly because it has to avoid the hydraulics for the lift gate, and it's just right for a fuel cell we already own. I'm halfway through the install, and someone comments that he doesn't know if it won't pass inspection with a fuel cell installed behind the rear wheels of the trailer.
I started trying to find out, but haven't been able to find any information on this whatsoever. Does anyone here have any information on the subject or know where I could go to get the information needed?
Thanks,
Ryan
TheRabbit 09-30-2010 05:08 PM
You're going to have to look into the DOT laws of your state.
zipper06 09-30-2010 07:40 PM
Kinda curious how this plays out, obviouly some motorhomes have the tank behind the rear wheels and they are DOT approved.
andamo 10-01-2010 04:28 AM
As someone mentioned, it's probably going to have to be checked by the DOT. Not knowing the configuration of what you have, you should consider what might happen if a tire were to shred itself and start hitting the cell. With the metal bands in the tires a spark could easily occur. Also, you should make sure the bottom of the cell, and fuel lines also, are above the scrub line of the chassis.
