-   -   car won/t shut off (https://www.racingjunk.com/forums/showthread.php?t=28875)
detoro 09-19-2010 03:48 PM
car won/t shut off
68 mustang 302 dist. has points changed the alt. car shut off 3 times after that but now won/t shut off with key thanks brad
Harbone 10-05-2010 08:33 PM
sloppy ignition switch? the tabs would break off on the back of the ignition cylinder and would engage to start but not disengage to turn off the power...
THERATTLER 03-05-2011 05:58 PM
if you went to a different type alternator you will have to put a diode in the ign wire going to alt
