Needing help with ET
My car isnt running the number it should be running.
Been asking around, chatting on other forums..Even done a couple calculators. Everyone has said i should be running 5.30. Builder of my engine says i should be running 5.80's. ET calculators say i should be running 5.30's. Best ive run is a 5.80 Coan Converter Coan T400 with no transbrake 4.88 rear gear 4 link Coil overs Lower 4 link bars are level with car running a 32 tall 14 wide tire, 60ft's range from 1.34s to 1.38s. Where to look first? Time to pull the converter and get it checked out? Its not even 2 years old and only has about 1 full season on it. |
Not saying the calculators are wrong but every car i've seen running 5.30's is in the low 1.20's 60' times and i don't know if you can do that with a footbrake car, you have too remember that the first 100' is the biggest gain in ET, the rest is smoking a cigarette and eating a sandwich. Put a transbrake in it and i'm sure you'll see the big improvment you are looking for.
JMO Zip. |
Well that makes me fell a little bit better.
Here's an example, from the GM super show this yr..
The right hand ticket, both cars are friends of mine. The # 3 car is a 3900lb Biscyne and the car in the right lane is a Luv truck, footbrake with a 434" on Nitrous, the tickets are not real clear, but you'll see 1.27 60' on the truck and 5.49 1/8 et. and 8.60's 1/4 mi on the truck. It's a true 10.5 tire truck. Zip. http://img.photobucket.com/albums/v5...2010ET-1-1.jpg |
| All times are GMT -8. The time now is 03:30 AM. |
