-   -   nitrous jet sizing (https://www.racingjunk.com/forums/showthread.php?t=28807)
davesnoscoupes 09-07-2010 06:15 PM
nitrous jet sizing
when chosing jet sizes for nitrous systems, should you go by the plate manufacturer or the solenoid manufacturer?
I have NX solenoids and an edlebrock plate, should I use the edelbrock jet map chart?
chevyfireball 09-08-2010 02:09 AM
I would use the solenoid manufacturers specs because its the solenoids that handle any potential flow. The plate will handle whatever jets you put in there.
wrightway 09-08-2010 04:27 AM
Go by the plate the jets go in the plate and the plate does the mixing
Unless your solenoids are too small they will out flow the plate
Solenoid = on/off
jet = restriction/calibration
plate= mixing/distribution of fuel
davesnoscoupes 09-11-2010 08:47 PM
Well, any other suggestions, lol
ccperf721p 09-11-2010 10:11 PM
Normally I would say go with the plate, but Edelbrock's jet map is on the rich side by quite a bit. But there are other factors to consider as well.
Which NX nitrous side solenoid do you have? The 15100 is a small orifice solenoid which will make a difference in N2O jet sizing.
