-   -   DUI Distributor oil leak (https://www.racingjunk.com/forums/showthread.php?t=28773)
reeves57 09-01-2010 04:46 PM
I istalled a DUI distributor on my 79 Celica 20R. Got everything installed and wired up, but when I started the car, oil started leaking out of a small pin about three inches above the base of the distributor. I called LC Engineering and they told me to call Performance Distributors. I gotta call them tomorrow. But, for now, does anyone know a quick fix for this problem? I thought about just lowering my oil pressure a little ( it was a little high anyway) and pluging the hole. Will this burn up the distributor? Any help will be greatly appreciated! Wanted to get 'er runnin' for the weekend, but if i have to remove and return the distributor, i may not be able to. Thanks in advance. :cry:
reeves57 09-02-2010 06:54 AM
Finally got in touch with Performance Distributors and they said it was OK to just plug the hole. Thanks for all the help!
