PLUG GAP
CURIOUS,IS A BIGGER GAP BETTER,WHY DO SOME RUN SMALL GAPS AND OTHERS LARGER GAPS?
The wider the gap the more resistance and the harder the ignition has to work to fire the plug.
A smaller or narrower gap will actually have a fatter spark kernel than a plug gapped wider. On high compression motors on gas I run between .028 .032 Cp |
45? What is your motor? I run 20-25 on a 632 nitrous motor.
I run NGK 8's or 9's with gas or alcohol, if i'm running the V-gaps i set them at .022, gas or alcohol, if i'm running the ES version (flat tip) i set them at .025. All use MSD ignition. In my opinion .045 is way out of range. I know that the old HEI setups GM called for .040/.045, but with multi-spark-discharge aka MSD you'll get much better firing of fuel charge setting them at less than .030.
JMO Zip. |
We see .035 to .040 gap makes peak power on most small blocks. If your using a mag then lower to around .025
HOW COME MSD CALL'S FOR .040-.050? USING A 6AL OR 6AL-2
DO YOU THINK NGK 7'S ARE TO HOT? JMO Zip. |
I think the 7's are more of a street application on pump gas. i run NGK 8's in my 377" on alcohol, and we run ES8's with a pump gas 468 b/blk shooting 200 shot of nitrous. I run NGK 9's in my blown alcohol sm/blk. I think the 8's would be better for your engine.
JMO Zip. |
| All times are GMT -8. The time now is 02:35 PM. |
