-   -   Hurst Shifter for TH350 - No 3rd Gear (https://www.racingjunk.com/forums/showthread.php?t=28693)
jreiley 08-22-2010 02:41 PM
Had a tranny brake installed into my th350, put on a reverse valve hurst shifter and cannot get it into 3rd gear. Park, Reverse, and neutral are all there. When I pull the lever back I get 4 shift points instead of just 3. When I pull it all the way into what should be third and then go forward to 1st and then go back to 3rd, it only has the 3 shift points. When I'm on the track it never goes into 3rd. I'm thinking linkage. Hopefully. Any ideas?
