-   -   Hose Sleeves (https://www.racingjunk.com/forums/showthread.php?t=28615)
jreiley 08-11-2010 03:49 PM
Hose Sleeves
Is there a good way to cut these stainless hose sleeves to fit hoses I want tp cover? Hack Saw is not the best.
fla1976 08-11-2010 05:00 PM
Wrap the point where you want to cut with vinyl tape and cut it with a dremel tool.
TheYellaBrick 08-11-2010 06:18 PM
I wrap mine with duct tape and cut with a cutoff saw. If you use a cutoff wheel on a die grinder or a cutoff saw, go SLOW so you don't catch the braid and unravel it all over. Just eeeeeease through it.
Scooterz 08-12-2010 01:13 PM
Amen on both of those comments... make sure you wrap it tight.
bowtie4542001 08-12-2010 06:34 PM
Same here, I just wrap the part I need to cut with tape and cut it with a cut off wheel.
Chris
