alternator and mid-plate??
Any trick to running an alternator with a front mid-plate on a BBC ....
Thaks |
If you mean a front motor plate here is an option.
http://img.villagephotos.com/p/2006-...8/IM000864.JPG Curtis |
Curtis, won't that alternator charge backwards?
Sorry, brother I couldn't resist.lmao |
to keep it from charging backwards you can mount it below the crankshaft
bottom--YOU WOULD HAVE UNDERDRIVE THEN AND MAKE BIG HORSEPOWER!!! :lol: :lol: :lol: |
My battery has too much power and I use it to suck some out. :D :D
Curtis |
You can also use the lower mount by powermaster with a mandrel to align the belt.
I think I used the No. 63844 on one of my motors.( Scroll down a little bit and you'll see it) http://www.moroso.com/catalog/catego...?catcode=18302 http://www.powermastermotorsports.com/bracket_kits.html |
Dooracer ...whose kit is that in the picture..Thanks
I made it myself. I run a machine shop so it is easy for me to write a program and machine up what I need. I also made the one piece drive mandrel / pulley. Curtis |
I like it.. I am going to have to do something like that on mine..
I run a homeade bracket with a backwards mounted alternator on my blown street rod
| All times are GMT -8. The time now is 10:14 PM. |
