Q16
Anyone using Q16 that can tell me the pro's and con's? I have a 468 bracket motor making about 640hp in a 2550lbs car and I use 110 fuel, I have heard alot of good things about using Q16 but I want to know what the down side would be. Thanks
Q-16
I will say it stinks and needs to be flushed out when parked or it can cause problems in your carb,but with proper jetting it does make more power, if you are running 110 now I would say you need 113 instead of Q-16. Later J.Smith 4621 racing
I can tell you, your motor does need q16, 112 would be fine. Whats your want to change ?
I can tell you its $$ stuff |
Q16
I'm looking for consistency between runs, lower engine temps. when I have to round robin and always more HP.
Re: Q16
Sounds to me like you should be looking for a alky carb ;) it'd fix all them issues in 1 shot for sure. |
The VP113 and Q16 are very consitent, but not gonna run any cooler than any other fuel. I agree the VP113 would work just fine for you and cheaper.
| All times are GMT -8. The time now is 04:07 AM. |
