-   -   Dana 30 (https://www.racingjunk.com/forums/showthread.php?t=28510)
showbusiness 07-26-2010 02:40 AM
Dana 30
Looking for advice on front diff. for mud racer,have dana 30 with detroit which i broke side gears in and was wondering if an open carrier would work ,run boggs and fast track,have 35 dean cuts frt.on carbon fibre mrt. wheels and 39.5 dean cuts on similar wheels rear.Thanks :?: :?: :?:
TheRabbit 07-26-2010 04:39 AM
Get ride of the locker, run a mild limited slip or open.
I run open. I can run the exact same times with my front hubs unlocked as I can with 'em locked. Front end is useless when you're hooking good.
showbusiness 07-26-2010 02:18 PM
Thanks,any choices for a limited slip,I am installing a open carrier for now and i guess the results will answer. :wink: :wink:
TheRabbit 07-26-2010 03:08 PM
I've run the powerlock in 44's with good luck. My 30 is just open.
