What fuel
Hey guys, its getting about that time for me to fire up the Opel. :D All I have left to do is have some headers made. My question is what fuel do I need to run, The engine is a 418 18degree SBC with 13:8 to 1 CR. I know that I can get 110 (purple colored) pretty close by. I was informed that I needed 112 but wanted to double check. Also is C12 the same as 112? If I need 112, could it be possible to mix 110 and 112. The reason I ask is the place I called about getting 112 said that is was $65 for 5 gallons. That seems a little high to me. Sorry about all the questions. Thanks in advance.
Chris |
i would call vp racing fuels and ask them what to use.
I will run 110 up to 14:1, but I will take camshaft design into account. 106 - 108 sep with 268+ intake duration doesn't have the dynamic compression ratio that I feel warrants C12. I have 3 customer engines in the 13.5 - 14.0 range that run every weekend on 110, they are on a 3 season freshen up cycle 2 have been freshened up once and one is on it's second freshen up cycle with the original pistons.
I moved my car to alcohol some time ago, cost per run was cut in half, makes better power, cool down time is basically nothing which takes one more thing out of equation, allowing me to prepare for the next round a little better. Makes it nice being able to basically hot lap a 7 second altered. |
Thanks guys, I will call VP to double check. There is a big difference in what I would have to pay for 112 ad what I can get 110 for.
I just got through talking with VP and they suggest using C12. I guess I will have to bite the bullet. I have always used 110 I got from BP.
Fuel
Switch that SB over to Methenol,or E-85!That Race Fuel Price thing is BU!!$#!T!! @13.8 that motor would be a GREAT E-85 Canadate!! You Here guys Complain about Alcohol.but @ 1.85 per Gallon,that about what 1 Runs takes for Me,1 to 1 1/2 Gallons.So there AINT NO Room for that OVERPRICED Race Gas around Here!!! Later G 8) |
Re: Fuel
VP113™
Offering substantial power gains at a competitive price, VP113 is oxygenated to street gas levels. Formulated for naturally aspirated engines with CRs up to approximately 14:1. VP113 makes up to 2% more power than competitive 110 octane fuels, with gains of 3-4% in engine applications with poor or marginal fuel vaporization qualities. Its oxygenation also yields a higher effective octane rating and greater protection against detonation. May require a tuning change, including increase in jet size, for optimum performance. I run the Q16, but this will work just fine for you. |
Hey guys, appreciate all the info. Looks like I will be switching over to alcohol. I can get it for $5 a gallon vise $12.60 a gallon. I will be doing a lot of reading on what I need to do as far as maintenance and running top lube and all. Never ran alcohol before.
Curtis |
| All times are GMT -8. The time now is 09:33 PM. |
