-   -   gear brand choices (https://www.racingjunk.com/forums/showthread.php?t=28453)
showbusiness 07-16-2010 05:24 PM
gear brand choices
Is there a good better best brand of ring and pinion sets for a dana 44 rear.Have a 2000 lb mud racer with 700 plus hp and 40 in cuts and twisted piion off just behind front bearing, any comments welcome . :shock: :!:
TheRabbit 07-16-2010 05:38 PM
Can the 44 for a 9". A strange "Drag Gear" ( 9310 steel) will hold up as good as any. If you have the gear lightened it's good for 50 passes. If it's a standard gear no more than 75 passes. You may get a little more out of it with only 700hp and 2,000lbs, but the gears start cracking real quick after that many passes.
You running 40 hawgs or 39.5 swampers? Swampers bite a lot harder than the hawgs.
showbusiness 07-16-2010 06:14 PM
Thanks, I was thinking that and tires are boggers,are there any choices for the dana . :oops: :oops:
TheRabbit 07-16-2010 06:22 PM
You can get the same drag gear for most rear ends, but in the long run you will be better off with a good 9". Ford did do at least one thing right!!
DO NOT USE A YUKON GEAR in the rear. Ok for the front, but never in the rear.
showbusiness 07-17-2010 01:36 AM
It was a YUKON gear set ,and yes to the 9 in. ,this is a narrowed rear with a 4 link, I suppose the 9in could be built the same. 8) Thanks
TheRabbit 07-17-2010 04:15 AM
This is my Moser 9". It's narrowed 8 "'s.
You'll have much better performance out of a good gear than you did the Yukon. However, no matter what gear they only hold up for so long.
http://i163.photobucket.com/albums/t...Rabbitrear.jpg
