-   -   need help with front coil springs (https://www.racingjunk.com/forums/showthread.php?t=28382)
bowhay 07-03-2010 08:53 AM
im trying to install my coil springs and control arms on a 80 t/a but everytime i try to jack up the bottom arm the body of the car starts to lift, any suggesions or tricks i could try?
oldandtired 07-03-2010 08:59 AM
You probably have no motor / trans weight to compress the springs.
Coil spring compressor is the safest way. I have also run a chain around the frame and under a floor jack, jacking against the lower a arm. It's dangerous no matter how you do it. Lots of kinetic energy that would love to jump out and bite you.
DirkaDirka 07-03-2010 09:01 AM
Is there a way you can anchor the body down to the floor to prevent it from lifting??
bowhay 07-03-2010 09:04 AM
no theres not, where might i find a coil spring compressor or would i have to order it
DirkaDirka 07-03-2010 09:16 AM
If you have an auto part store around they should have tools you can rent.
bowhay 07-03-2010 09:45 AM
alrighty then thanks
Tod74 07-03-2010 11:07 AM
Look in the yellow pages for a spring place.There is a place in Indy that sells springs and For around $20 they will compress a pair of springs for you and band them together.You just instal everything then reach in with some cutters and cut the band.
bowhay 07-05-2010 11:32 AM
i went and got one from the parts store and got it done, thanx for the help guys
TheRabbit 07-05-2010 12:45 PM
FYI, Harbor Freight has a cheap coil spring compressor if you only need to use one every now and then.
TheYellaBrick 07-05-2010 01:26 PM
ESPECIALLY for this particular job, I would NEVER use a cheap Chinese junk tool. :shock: :shock: :shock: :shock: Good way to loose your head !!
Load it on a car trailer and tie it down to so you can use a floor jack under the 'A'arm to compress it.
